Publication date: 02/06/2025
Bayesian Estimates Report Options
The Bayesian Estimates <N> red triangle menu contains the following options:
Export Monte Carlo Samples
Creates a new data table where each row of the data table corresponds to a single sample from the posterior distribution. This data table contains the number of rows equal to the number of Monte Carlo iterations. The data table also contains scripts to assist in examining the posterior samples.
Export Stacked Monte Carlo Samples
Creates a new data table where the rows for each value of the Label, System ID variable are stacked vertically. This data table contains the number of rows equal to the number of Monte Carlo iterations times the number of levels of the Label, System ID variable.
Show Diagnostics
Shows or hides the Diagnostics section of the report.
Change Life Distribution Profilers
Enables you to change the settings for the simulated realizations of the posterior samples. These simulated realizations are used in the Life Distribution Profilers report.
Remove Life Distribution Profilers
(Available only when the Life Distribution Profilers report is visible.) Removes the Life Distribution Profilers section of the Bayesian Estimates <N> report.
Show Life Distribution Profilers
(Available only when the Life Distribution Profilers report is not visible.) Adds the Life Distribution Profilers section to the Bayesian Estimates <N> report.
Remove Fit
Removes the current Bayesian Estimates <N> report from the Response report.
