Scripting Guide > Python > Install a Python Package > Avoiding Issues with NumPy and Matplotlib
Publication date: 02/06/2025
JMP attempts to load NumPy and Matplotlib when initializing Python, therefore attempting to install them through the Python environment by using the jmputils package will cause errors for Windows users after they have been initially installed. If one of these packages causes a conflict, close JMP and use the jpip wrapper script in the command line. See Using the Terminal or Command Line to Work with jpip.
