Scripting Guide > Scripting Platforms > Apply a Platform Preset to a Data Table
Publication date: 02/06/2025
You can apply a platform preset object from one object to another object of the same type using the << Apply Preset message. The following example saves a Oneway analysis of two columns from the Big Class.jmp sample data as a platform preset then applies that preset to two columns from the Dogs.jmp sample data.
Names Default To Here( 1 );
obj = dt << Oneway( Y( :height ), X( :sex ), t Test( 1 ) );
preset = obj << New Preset();
dt2 = Open( "$SAMPLE_DATA/Dogs.jmp" );
obj2 = dt2 << Oneway( Y( :LogHist0 ), X( :drug ) );
Wait( 1 );
obj2 << Apply Preset( preset );
You can also search for a preset to apply to an object. The following example applies the Compare Distributions preset from the Sample Presets folder to a data set.
obj = dt << Oneway( Y( :height ), X( :sex ) );
Wait( 1 );
obj << Apply Preset( "Sample Presets", "Compare Distributions" );
