Discovering JMP > Analyze Your Data > Analyze Distributions
Publication date: 02/06/2025
To analyze a single variable, you can examine the distribution of the variable, using the Distribution platform. Report content for each variable varies, depending on whether the variable is categorical (nominal or ordinal) or continuous.
Note: For more information about the Distribution platform, see “Distributions” in Basic Analysis.
