Publication date: 02/06/2025
Additional Options
The Time Series red triangle menu also contains the following options:
Combine and Save Forecasts from Models
Creates a new data table with the combined results from all model fits in the report.
Save Spectral Density
Creates a new data table containing the spectral density and periodogram where the (i+1)th row corresponds to the frequency fi = i / N (that is, the ith harmonic of 1 / N). The new data table has the following columns:
Period
The period of the ith harmonic, 1 / fi.
Frequency
The frequency of the harmonic, fi.
Angular Frequency
The angular frequency of the harmonic, 2πfi.
Sine
The Fourier sine coefficients, ai.
Cosine
The Fourier cosine coefficients, bi.
Periodogram
The periodogram, I(fi).
Spectral Density
The spectral density, a smoothed version of the periodogram.
Number of Forecast Periods
Shows a window that enables you to set the number of future periods that are forecast for the fitted models. The initial value is set in the Time Series launch window. All existing and future forecast results use the new number of periods once it is changed.
Maximum Iterations
Shows a window that enables you to reset the maximum number of iterations for future optimizations used in fitting ARIMA models.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
