Using JMP > JMP Reports > Use Markers in JMP Graphs > Add Outlines Around Markers
Publication date: 02/06/2025
You can add a dark color outline, or frame, to markers in a JMP plot or graph. Outlined markers are available at the medium, larger, XL, XXL, and XXXL marker size. See Change the Size of Markers.
To add outlines
1. Right-click a plot or graph.
2. Select Marker Drawing Mode.
3. Select Outlined.
To use an outline effectively, it is best if your marker is a color other than black.
To change marker colors
1. Highlight the markers whose color you want to change.
2. Right-click anywhere in the graph.
3. Select Row Colors.
4. Select a marker color from the options that appear.
