CASE STUDY: JMP034
Durability of Mobile Phone Screen
Part 3
by Kevin Potcner, JMP Global Academic Team
Key Concepts: Single variable logistic regression, inverse prediction
Objective
Evaluate the durability of mobile phone screens in a drop test across various heights by building individual simple logistic regression models. Use the models to estimate the probability of a screen being damaged across any drop height.
Background
The durability of a product is clearly an important quality characteristic for both the end user and the manufacturer. For end users, durability is especially important for mobile phones. Dropping a phone on a hard surface, for example, can result in the screen cracking or even breaking, rendering the phone unusable. To evaluate the durability of these screens, manufacturers subject a sample of screens to a variety of tests to simulate typical wear and tear by a user, such as dropping the phone onto a concrete surface.
In JMP032 Durability of Mobile Phone Screen - Part 1, material scientists for a screen manufacturer experimented with two new formulations of an aluminosilicate glass (A and B). These two formulations were produced by making a change to a final processing step that uses a specific level of potassium nitrate to strengthen the glass.
A sample of 10 screens of each type was developed for testing. Each screen was installed into the same style of phone. The phones were then dropped in a controlled identical manner from a height of 1 meter onto a concrete surface. A binary variable “Success” (no damage) and “Fail” (screen damage) was recorded.
One of the company’s goals is that 97% of the screens manufactured would be able to experience a drop of 1 meter without becoming damaged (i.e., the Population Success Rate).
The analyses illustrated in JMP032 Durability of Mobile Phone Screen - Part 1, which were based on only 10 phones tested of each Screen Type, failed to generate the statistical evidence needed to demonstrate the desired Success Rate. The analyses also failed to find any statistically significant difference between the two Screen Types.
The engineers decided to test an additional 40 phones for each of the two Screen Types. Analyzing the results from this expanded test was the objective of the exercises for that case study.
In case JMP033 - Durability of Mobile Phone Screen - Part 2, the material scientists developed a third Screen Type (C), which required a more expensive process. Tests were done for this Screen Type at 1.0m, as had been done for Screen Types A and B. In an effort to gain a comprehensive understanding of the durability of these screens, the engineers conducted the drop test at two additional heights (0.5 and 1.5 meters), which resulted in the following data:
Type A
n=40
S=36
F=4
n=50
S=41
F=9
n=50
S=28
F=22
Type B
n=40
S=40
F=0
n=50
S=48
F=2
n=50
S=40
F=10
Type C
n=40
S=39
F=1
n=50
S=47
F=3
n=50
S=39
F=11
These data were analyzed in case JMP033 - Durability of Mobile Phone Screen - Part 2. To continue developing a deeper understanding of the performance of the Screen Types, the engineers performed additional tests at Drop Heights of 0.25m, 1.25m, 2.0m, 2.5m and 3.0m. In addition, a sample of screens from a leading competitor were obtained and included in the testing, resulting in the following data, seen in the PDF.
The Task
The primary objectives of this analysis are to:
- Describe how the performance of each Screen Type changes as the Drop Height changes.
- Describe differences in durability between the three Screen Types.
- Determine how the company’s three Screen Types compare to the screens of its competitor.
- Develop a tool that will estimate the Success Rate at any Drop Height, including those not part of the testing.
- Determine the Drop Height at which it is estimated that the Success Rate would be at least 97% for each Screen Type.
